Проблемы Tap-адаптера?
3 года 11 мес. назад #7 от ZAndrew
При переподключении в полночь User8362 не подключился автоматически, а выдал окошко, что имя пользователя и пароль неправильные (строки с именем и паролем были заполнены автоматически). Нажали ОК - через некоторое время подключился. Что могли бы сказать по этому логу? В чем причина повторного запроса ученых данных?
Также в этот же момент выскочило такое же окошко у User8361.
User8362:
Wed Jun 03 00:01:52 2020 Connection reset command was pushed by server ('[N]')
Wed Jun 03 00:01:52 2020 SIGUSR1[soft,server-pushed-connection-reset] received, process restarting
Wed Jun 03 00:02:03 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:02:03 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:02:03 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:02:03 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:03:03 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 03 00:03:03 2020 TLS Error: TLS handshake failed
Wed Jun 03 00:03:03 2020 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 03 00:03:08 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:03:08 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:03:08 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:03:08 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:04:08 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 03 00:04:08 2020 TLS Error: TLS handshake failed
Wed Jun 03 00:04:08 2020 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 03 00:04:13 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:04:13 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:04:13 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:04:13 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:04:51 2020 TLS Error: reading acknowledgement record from packet
Wed Jun 03 00:04:54 2020 [VPNKI] Peer Connection Initiated with [AF_INET]84.201.157.25:35886
Wed Jun 03 00:05:56 2020 No reply from server after sending 12 push requests
Wed Jun 03 00:05:56 2020 SIGUSR1[soft,no-push-reply] received, process restarting
Wed Jun 03 00:06:01 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:06:01 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:06:01 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:06:01 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:06:08 2020 TLS Error: Unroutable control packet received from [AF_INET]84.201.157.25:35886 (si=3 op=P_ACK_V1)
Wed Jun 03 00:06:08 2020 TLS Error: Unroutable control packet received from [AF_INET]84.201.157.25:35886 (si=3 op=P_CONTROL_V1)
Wed Jun 03 00:06:09 2020 [VPNKI] Peer Connection Initiated with [AF_INET]84.201.157.25:35886
Wed Jun 03 00:06:11 2020 AUTH: Received control message: AUTH_FAILED
Wed Jun 03 00:06:11 2020 SIGUSR1[soft,auth-failure] received, process restarting
Wed Jun 03 00:06:24 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:06:24 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:06:24 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:06:24 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:07:24 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Wed Jun 03 00:07:24 2020 TLS Error: TLS handshake failed
Wed Jun 03 00:07:24 2020 SIGUSR1[soft,tls-error] received, process restarting
Wed Jun 03 00:07:29 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Wed Jun 03 00:07:29 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:07:29 2020 UDP link local (bound): [AF_INET][undef]:1194
Wed Jun 03 00:07:29 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Wed Jun 03 00:07:44 2020 TLS Error: reading acknowledgement record from packet
Wed Jun 03 00:07:46 2020 [VPNKI] Peer Connection Initiated with [AF_INET]84.201.157.25:35886
Wed Jun 03 00:08:21 2020 open_tun
Wed Jun 03 00:08:21 2020 TAP-WIN32 device [Ethernet 4] opened: \\.\Global\{610E0D5F-DA3E-41F8-8ABC-E7F6796B2AAB}.tap
Wed Jun 03 00:08:21 2020 Set TAP-Windows TUN subnet mode network/local/netmask = 172.16.0.0/172.16.29.27/255.255.0.0 [SUCCEEDED]
Wed Jun 03 00:08:21 2020 Notified TAP-Windows driver to set a DHCP IP/netmask of 172.16.29.27/255.255.0.0 on interface {610E0D5F-DA3E-41F8-8ABC-E7F6796B2AAB} [DHCP-serv: 172.16.255.254, lease-time: 31536000]
Wed Jun 03 00:08:21 2020 Successful ARP Flush on interface [12] {610E0D5F-DA3E-41F8-8ABC-E7F6796B2AAB}
Wed Jun 03 00:08:26 2020 Initialization Sequence Completed
3 года 11 мес. назад - 3 года 11 мес. назад #8 от admin
Попробуйте вот что:
- создайте в директории, где лежит конфигурация соединения, файл с логином и паролем. Пусть это будет login.txt
в нем будут лишь две строки (замените на ваши данные)
user8798798798
paswooord
- теперь измените конфигурационный файл подключения, добавив в него ссылку на созданный файл.
В моем варианте, в конфиге была пустая команда auth-user-pass, а я добавил к ней путь к файлу вот в таком виде:
auth-user-pass "C:\\Users\\<windows-user>\\OpenVPN\\config\\vpnki_account\\login.txt"
(Вместо выделенного текста подставьте свои данные) Главное, чтобы путь был корректным и с двойными слэшами \\
Все остальные данные файла конфигурации оставьте как и были.
Теперь OpneVPN будет устанавливать соединение и брать логин/пароль из файла. Такое будет как при первоначальном установлении соединения, так и при переподключении в 00-00.
Установите соединение, теперь клиент ничего не запросит в окошке, а возьмет данные из файла.
После установления соединения зайдите в личный кабинет VPNKI и перезапустите процесс OpenVPN кнопкой перезапуска.
Вы увидите, что ваш клиент отключился. И через некоторое время может быть подключится.
3 года 11 мес. назад #9 от ddd0251
Заработало??? У меня почему то так и не работает и проблема то не в отсутствии пароля, а в том что почему-то пишит что пароль не верный именно в 00.00, а если вручную остановить и потом запустить то все работает
3 года 11 мес. назад #10 от admin
ddd0251 пишет: Заработало??? У меня почему то так и не работает и проблема то не в отсутствии пароля, а в том что почему-то пишит что пароль не верный именно в 00.00, а если вручную остановить и потом запустить то все работает
У меня вопрос - Вы сделали так как я написал, проверили с перезапуском OpenVPN на сервере вручную и это не работает?
3 года 11 мес. назад #11 от ddd0251
Если перезапустить опенвпн вручную с сайта или приложения, то клиен подключается безпроблем, но в 00.00 опять вылезла ошибка пароль или логин неверный. Может быть вам у себя можно сделать какую то задержку??? Может быть ваш сервер считает что клиент с таким логином подключён, поэтому и вылазеет ошибка???
3 года 11 мес. назад - 3 года 11 мес. назад #12 от admin
Нет-нет, я все таки не понял - вы внесли изменения в конфигурационный файл и сейчас логин /пароль прописаны в отдельном файле? Мне это важно для понимания ситуации.
Я могу попробовать поставить вас в верхнюю часть списка перезапуска для того, чтобы процесс рестарта демона завершился быстрее.
Но все равно это время не равно нулю и если ваш клиент в это время попробует подключиться и пароль не пройдет, то возможны варианты. С другой стороны, от того, что кдиент один раз не достучался до сервера не означает, что больше этого делать не нужно. Он должен был бы продолжать.
