Маршрутизатор zyxel нет подключения к туннелю
  • iskra31
5 года 9 мес. назад #9 от iskra31
iskra31 пишет: Результат тот же!
Подключение не происходит
5 года 9 мес. назад #10 от admin
1. Странно, в логе я продолжаю видеть попытки CHAP
Aug 7 13:49:11 VPNKI pptpd[32072]: CTRL: Client 37.139.84.9 control connection started
Aug 7 13:49:11 VPNKI pppd[32032]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Aug 7 13:49:11 VPNKI pppd[32032]: Both 40-bit and 128-bit disabled, disabling MPPE since it was optional.
Aug 7 13:49:11 VPNKI pppd[5798]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Aug 7 13:49:11 VPNKI pppd[5798]: Both 40-bit and 128-bit disabled, disabling MPPE since it was optional.
Aug 7 13:49:11 VPNKI pppd[1082]: CCP: timeout sending Config-Requests
Aug 7 13:49:11 VPNKI pppd[24783]: CCP: timeout sending Config-Requests
2. Включено ли шифрование соедиения? Если да, то с CHAP оно не работает, а работает только с MS-CHAPv2
Вы сможете перезагрузить устройство?
Что-нибудь вчера менялось на вашем Кинетике?
5 года 9 мес. назад #11 от admin
Пока MS-CHAPv2 не идет.
Aug 7 13:59:09 VPNKI pptpd[24576]: CTRL: Client 37.139.84.9 control connection started
Aug 7 13:59:09 VPNKI pptpd[24445]: CTRL: Starting call (launching pppd, opening GRE)
Aug 7 13:59:09 VPNKI pppd[11605]: CCP: timeout sending Config-Requests
Aug 7 13:59:09 VPNKI pppd[24578]: pppd 2.4.7 started by root, uid 0
Aug 7 13:59:09 VPNKI pppd[24578]: Using interface ppp177
Aug 7 13:59:09 VPNKI pppd[24578]: Connect: ppp177 <--> /dev/pts/220
Aug 7 13:59:09 VPNKI pppd[11052]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Aug 7 13:59:09 VPNKI pppd[11052]: Both 40-bit and 128-bit disabled, disabling MPPE since it was optional.
Aug 7 13:59:09 VPNKI pppd[24149]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Aug 7 13:59:09 VPNKI pppd[24149]: Both 40-bit and 128-bit disabled, disabling MPPE since it was optional.
Aug 7 13:59:09 VPNKI pppd[1208]: CCP: timeout sending Config-Requests
Aug 7 13:59:09 VPNKI pppd[5923]: CCP: timeout sending Config-Requests
Aug 7 13:59:09 VPNKI pppd[28571]: CCP: timeout sending Config-Requests
Aug 7 13:59:09 VPNKI pppd[28469]: CCP: timeout sending Config-Requests
Aug 7 13:59:09 VPNKI pppd[329]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Aug 7 13:59:09 VPNKI pppd[28571]: MS-CHAP[v2] auth not performed, disabling MPPE since it was optional.
Попробуйте поставить MS-CHAPv2 и включить(!) шифрование.
  • iskra31
5 года 9 мес. назад #12 от iskra31
admin пишет: 1. Странно, в логе я продолжаю видеть попытки CHAP
  • iskra31
5 года 9 мес. назад #13 от iskra31
Результат нулевой. Роутер перезагружали
5 года 9 мес. назад #14 от admin
Очень странно.
Скажите, у вас есть еще два туннеля, которые сейчас работают - там тоже PPTP?
