Проблемы Tap-адаптера?
4 года 10 мес. назад #16 от ZAndrew
Спасибо, это я сделал, помогло или нет пока не знаю, надо пару дней потестировать.
Будьте добры, посмотрите лог USER8361, почему не переподключается после обрыва соединения вашим сервером.
Thu Jun 04 00:56:49 2020 Connection reset command was pushed by server ('[N]')
Thu Jun 04 00:56:50 2020 SIGUSR1[soft,server-pushed-connection-reset] received, process restarting
Thu Jun 04 00:56:55 2020 WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Thu Jun 04 00:56:55 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.157.25:35886
Thu Jun 04 00:56:55 2020 UDP link local (bound): [AF_INET][undef]:1194
Thu Jun 04 00:56:55 2020 UDP link remote: [AF_INET]84.201.157.25:35886
Thu Jun 04 00:56:56 2020 [VPNKI] Peer Connection Initiated with [AF_INET]84.201.157.25:35886
Thu Jun 04 00:56:57 2020 open_tun
Thu Jun 04 00:56:57 2020 TAP-WIN32 device [Tap Adapter] opened: \\.\Global\{70B7BD83-4BE8-4FCD-B4C5-0CA328D3B27A}.tap
Thu Jun 04 00:56:57 2020 Set TAP-Windows TUN subnet mode network/local/netmask = 172.16.0.0/172.16.29.26/255.255.0.0 [SUCCEEDED]
Thu Jun 04 00:56:57 2020 Notified TAP-Windows driver to set a DHCP IP/netmask of 172.16.29.26/255.255.0.0 on interface {70B7BD83-4BE8-4FCD-B4C5-0CA328D3B27A} [DHCP-serv: 172.16.255.254, lease-time: 31536000]
Thu Jun 04 00:56:57 2020 Successful ARP Flush on interface [14] {70B7BD83-4BE8-4FCD-B4C5-0CA328D3B27A}
Thu Jun 04 00:57:32 2020 SYSTEM ROUTING TABLE
Thu Jun 04 00:57:32 2020 0.0.0.0 0.0.0.0 10.181.118.109 p=0 i=25 t=4 pr=3 a=96522 h=0 m=70/0/0/0/0
Thu Jun 04 00:57:32 2020 10.181.118.108 255.255.255.252 10.181.118.110 p=0 i=25 t=3 pr=2 a=96522 h=0 m=326/0/0/0/0
Thu Jun 04 00:57:32 2020 10.181.118.110 255.255.255.255 10.181.118.110 p=0 i=25 t=3 pr=2 a=96522 h=0 m=326/0/0/0/0
Thu Jun 04 00:57:32 2020 10.181.118.111 255.255.255.255 10.181.118.110 p=0 i=25 t=3 pr=2 a=96522 h=0 m=326/0/0/0/0
Thu Jun 04 00:57:32 2020 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=96649 h=0 m=331/0/0/0/0
Thu Jun 04 00:57:32 2020 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=96649 h=0 m=331/0/0/0/0
Thu Jun 04 00:57:32 2020 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=96649 h=0 m=331/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.0.0 255.255.0.0 169.254.105.37 p=0 i=23 t=3 pr=2 a=96638 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.0.0 255.255.0.0 169.254.158.226 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.105.37 255.255.255.255 169.254.105.37 p=0 i=23 t=3 pr=2 a=96638 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.158.226 255.255.255.255 169.254.158.226 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.255.255 255.255.255.255 169.254.105.37 p=0 i=23 t=3 pr=2 a=96638 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 169.254.255.255 255.255.255.255 169.254.158.226 p=0 i=14 t=3 pr=2 a=32 h=0 m=291/0/0/0/0
Thu Jun 04 00:57:32 2020 192.168.56.0 255.255.255.0 192.168.56.1 p=0 i=10 t=3 pr=2 a=96645 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 192.168.56.1 255.255.255.255 192.168.56.1 p=0 i=10 t=3 pr=2 a=96645 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 192.168.56.255 255.255.255.255 192.168.56.1 p=0 i=10 t=3 pr=2 a=96645 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=96649 h=0 m=331/0/0/0/0
Thu Jun 04 00:57:32 2020 224.0.0.0 240.0.0.0 192.168.56.1 p=0 i=10 t=3 pr=2 a=96648 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 224.0.0.0 240.0.0.0 169.254.105.37 p=0 i=23 t=3 pr=2 a=96648 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 224.0.0.0 240.0.0.0 10.181.118.110 p=0 i=25 t=3 pr=2 a=96647 h=0 m=326/0/0/0/0
Thu Jun 04 00:57:32 2020 224.0.0.0 240.0.0.0 169.254.158.226 p=0 i=14 t=3 pr=2 a=2179 h=0 m=291/0/0/0/0
Thu Jun 04 00:57:32 2020 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=96649 h=0 m=331/0/0/0/0
Thu Jun 04 00:57:32 2020 255.255.255.255 255.255.255.255 192.168.56.1 p=0 i=10 t=3 pr=2 a=96648 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 255.255.255.255 255.255.255.255 169.254.105.37 p=0 i=23 t=3 pr=2 a=96648 h=0 m=281/0/0/0/0
Thu Jun 04 00:57:32 2020 255.255.255.255 255.255.255.255 10.181.118.110 p=0 i=25 t=3 pr=2 a=96647 h=0 m=326/0/0/0/0
Thu Jun 04 00:57:32 2020 255.255.255.255 255.255.255.255 169.254.158.226 p=0 i=14 t=3 pr=2 a=2179 h=0 m=291/0/0/0/0
Thu Jun 04 00:57:32 2020 SYSTEM ADAPTER LIST
Thu Jun 04 00:57:32 2020 Realtek PCIe GbE Family Controller
Thu Jun 04 00:57:32 2020 Index = 12
Thu Jun 04 00:57:32 2020 GUID = {6BDFED73-A2E8-4B08-B310-DCC81C0A9320}
Thu Jun 04 00:57:32 2020 IP = 0.0.0.0/0.0.0.0
Thu Jun 04 00:57:32 2020 MAC = 04:92:26:4d:9b:f8
Thu Jun 04 00:57:32 2020 GATEWAY = 0.0.0.0/255.255.255.255
Thu Jun 04 00:57:32 2020 DHCP SERV =
Thu Jun 04 00:57:32 2020 DHCP LEASE OBTAINED = Thu Jun 04 00:57:32 2020
Thu Jun 04 00:57:32 2020 DHCP LEASE EXPIRES = Thu Jun 04 00:57:32 2020
Thu Jun 04 00:57:32 2020 DNS SERV =
Thu Jun 04 00:57:32 2020 Npcap Loopback Adapter
Thu Jun 04 00:57:32 2020 Index = 23
Thu Jun 04 00:57:32 2020 GUID = {D5AEA729-C2CA-470E-8190-9F933BC1FAF7}
Thu Jun 04 00:57:32 2020 IP = 169.254.105.37/255.255.0.0
Thu Jun 04 00:57:32 2020 MAC = 02:00:4c:4f:4f:50
Thu Jun 04 00:57:32 2020 DHCP SERV = 0.0.0.0/255.255.255.255
Thu Jun 04 00:57:32 2020 VirtualBox Host-Only Ethernet Adapter
Thu Jun 04 00:57:32 2020 Index = 10
Thu Jun 04 00:57:32 2020 GUID = {5D98AB3D-CD7B-4DE7-B82A-68CBE5B61540}
Thu Jun 04 00:57:32 2020 IP = 192.168.56.1/255.255.255.0
Thu Jun 04 00:57:32 2020 MAC = 0a:00:27:00:00:0a
Thu Jun 04 00:57:32 2020 TAP-Windows Adapter V9
Thu Jun 04 00:57:32 2020 Index = 14
Thu Jun 04 00:57:32 2020 GUID = {70B7BD83-4BE8-4FCD-B4C5-0CA328D3B27A}
Thu Jun 04 00:57:32 2020 IP = 169.254.158.226/255.255.0.0
Thu Jun 04 00:57:32 2020 MAC = 00:ff:70:b7:bd:83
Thu Jun 04 00:57:32 2020 HUAWEI Mobile Connect - 3G Network Card
Thu Jun 04 00:57:32 2020 Index = 25
Thu Jun 04 00:57:32 2020 GUID = {F2D567A1-9885-4A03-9B76-A4D8946E0273}
Thu Jun 04 00:57:32 2020 IP = 10.181.118.110/255.255.255.252
Thu Jun 04 00:57:32 2020 MAC = 00:1e:10:1f:2e:38
Thu Jun 04 00:57:32 2020 GATEWAY = 10.181.118.109/255.255.255.255
Thu Jun 04 00:57:32 2020 DHCP SERV = 10.181.118.109/255.255.255.255
Thu Jun 04 00:57:32 2020 DHCP LEASE OBTAINED = Thu Jun 04 00:08:55 2020
Thu Jun 04 00:57:32 2020 DHCP LEASE EXPIRES = Thu Jun 04 02:08:55 2020
Thu Jun 04 00:57:32 2020 DNS SERV = 10.221.41.1/255.255.255.255 10.220.41.1/255.255.255.255
Thu Jun 04 00:57:32 2020 Initialization Sequence Completed With Errors ( see openvpn.net/faq.html#dhcpclientserv )
4 года 10 мес. назад #17 от ZAndrew
admin пишет: Попробуйте вот что:
- создайте в директории, где лежит конфигурация соединения, файл с логином и паролем. Пусть это будет login.txt
в нем будут две строки (замените на ваши данные)
user8798798798
paswooord
- измените конфигурационный файл подключения, добавив в него ссылку на созданный файл.
В моем варианте, в конфиге была пустая команда auth-user-pass, а я добавил к ней путь к файлу вот в таком виде:
auth-user-pass "C:\\Users\\<windows-user>\\OpenVPN\\config\\vpnki_account\\login.txt"
Все остальные данные файла конфигурации оставьте как и были.
Установите соединение.
Теперь клиент ничего не запросит в окошке, а возьмет данные из файла.
После установления соединения зайдите в личный кабинет VPNKI и перезапустите процесс OpenVPN кнопкой перезапуска.
Вы увидите, что ваш клиент отключился. И через некоторое время может быть подключится.
Так и сделал. Вот фрагмент файла. При отключении от сервера все равно выскакивает окошко с логином и паролем.
dev tun
auth-user-pass "C:\Users\Andrew\OpenVPN\config\vpnki_ZAndrew\login.txt"
explicit-exit-notify 2
4 года 10 мес. назад #18 от admin
ZAndrew пишет: Так и сделал. Вот фрагмент файла. При отключении от сервера все равно выскакивает окошко с логином и паролем.
dev tun
1. Нужно убедиться, что путь корректен, проверьте еще раз
2. В моем примере слэши были двойные \\ - возможно это важно.
Мой вариант был такой:
client
remote msk.vpnki.ru XXXXX
proto udp
cipher AES-128-CBC
ns-cert-type server
key-direction 1
dev tun
auth-user-pass "C:\\Users\\XXXXXXXXX\\OpenVPN\\config\\vpnki_XXXXXXXXXX\\login.txt"
auth-nocache
<ca>
BEGIN CERTIFICATE
MIIEqjCCA5KgAwIBAgIJAIXdev+7xO7gMA0GCSqGSIb3DQEBCwUAMIGUMQswCQYD
Ну и нужно переустановить соединение.
Ну и как вариант - возможно есть проблема с правами на чтение файла login.txt ?
Если все правильно, то при установлении соединения он не выкинет окошко с логином и паролем, а просто подключится.
4 года 10 мес. назад #19 от ddd0251
Вы что то поменяли ??? Сегодня переподключился без проблем
4 года 10 мес. назад #20 от admin
Нет, я ничего не менял
4 года 10 мес. назад #21 от ZAndrew
Проблема решена по инструкции от openvpn.
Reset Network TCP/IP stack
If your TCP/IP stack is corrupted it can be reseted with the following commands.
Windows XP:
1. Search for Command Prompt > Run As Administrator
2. netsh winsock reset
3. netsh int ip reset
4. ipconfig /flushdns
5. Restart computer
Windows Vista, 7, 8, 10:
2. netsh winsock reset catalog
3. netsh int ipv4 reset reset.log
4. netsh int ipv6 reset reset.log
5. Restart computer
Подключение и переподключение теперь автоматически.
