8 года 1 мес. назад #13 от Ivanpost67
Закомментировал все, ребутнул - нет pptp
8 года 1 мес. назад #14 от admin
Запустил дамп. Сейчас чисто.
Теперь запустите попытку установления соединения L2TP
8 года 1 мес. назад #15 от admin
Вы пробовали подключение? В последние 10 минут никакого трафика нет
8 года 1 мес. назад #16 от Ivanpost67
Может я вчера невнимательно смотрел... Сразу не работает. На 6м шаге есть ошибка.
pi@ServerPI:~ $ sudo ipsec restart
Stopping strongSwan IPsec...
Starting strongSwan 5.5.1 IPsec [starter]...
pi@ServerPI:~ $ sudo ipsec up vpnki-l2tp
initiating Main Mode IKE_SA vpnki-l2tp[1] to 193.232.49.4
generating ID_PROT request 0 [ SA V V V V V ]
sending packet: from 192.168.1.104[500] to 193.232.49.4[500] (240 bytes)
received packet: from 193.232.49.4[500] to 192.168.1.104[500] (140 bytes)
parsed ID_PROT response 0 [ SA V V V ]
received unknown vendor ID: 4f:53:57:79:5f:44:72:65:7a:65:47:53
received DPD vendor ID
received NAT-T (RFC 3947) vendor ID
generating ID_PROT request 0 [ KE No NAT-D NAT-D ]
sending packet: from 192.168.1.104[500] to 193.232.49.4[500] (372 bytes)
received packet: from 193.232.49.4[500] to 192.168.1.104[500] (356 bytes)
parsed ID_PROT response 0 [ KE No NAT-D NAT-D ]
local host is behind NAT, sending keep alives
remote host is behind NAT
generating ID_PROT request 0 [ ID HASH ]
sending packet: from 192.168.1.104[4500] to 193.232.49.4[4500] (76 bytes)
received packet: from 193.232.49.4[4500] to 192.168.1.104[4500] (76 bytes)
parsed ID_PROT response 0 [ ID HASH V ]
received unknown vendor ID: 49:4b:45:76:32
IKE_SA vpnki-l2tp[1] established between 192.168.1.104[192.168.1.104]...193.232.49.4[10.20.118.71]
generating QUICK_MODE request 1515464663 [ HASH SA No ID ID NAT-OA NAT-OA ]
sending packet: from 192.168.1.104[4500] to 193.232.49.4[4500] (204 bytes)
received packet: from 193.232.49.4[4500] to 192.168.1.104[4500] (92 bytes)
parsed INFORMATIONAL_V1 request 1812737666 [ HASH D ]
received DELETE for IKE_SA vpnki-l2tp[1]
deleting IKE_SA vpnki-l2tp[1] between 192.168.1.104[192.168.1.104]...193.232.49.4[10.20.118.71]
establishing connection 'vpnki-l2tp' failed
pi@ServerPI:~ $
8 года 1 мес. назад - 8 года 1 мес. назад #17 от admin
Так, подождите. Я же говорил пока выключить Ipsec - он пока только мешает.
Сейчас нужен только L2TP. Выключите ipsec и дайте знать о готовности - я запущу дамп еще раз.
8 года 1 мес. назад #18 от Ivanpost67
Sep 24 16:50:48 ServerPI systemd[1]: Starting LSB: layer 2 tunelling protocol daemon...
Sep 24 16:50:48 ServerPI xl2tpd[1889]: setsockopt recvref[30]: Protocol not available
Sep 24 16:50:48 ServerPI xl2tpd[1889]: Using l2tp kernel support.
Sep 24 16:50:48 ServerPI xl2tpd[1885]: Starting xl2tpd: xl2tpd.
Sep 24 16:50:48 ServerPI xl2tpd[1890]: xl2tpd version xl2tpd-1.3.8 started on ServerPI PID:1890
Sep 24 16:50:48 ServerPI systemd[1]: Started LSB: layer 2 tunelling protocol daemon.
Sep 24 16:50:48 ServerPI xl2tpd[1890]: Written by Mark Spencer, Copyright (C) 1998, Adtran, Inc.
Sep 24 16:50:48 ServerPI xl2tpd[1890]: Forked by Scott Balmos and David Stipp, (C) 2001
Sep 24 16:50:48 ServerPI xl2tpd[1890]: Inherited by Jeff McAdams, (C) 2002
Sep 24 16:50:48 ServerPI xl2tpd[1890]: Forked again by Xelerance (www.xelerance.com) (C) 2006-2016
Sep 24 16:50:48 ServerPI xl2tpd[1890]: Listening on IP address 0.0.0.0, port 1701
Sep 24 16:51:49 ServerPI xl2tpd[1890]: Connecting to host msk.vpnki.ru, port 1701
Sep 24 16:51:49 ServerPI xl2tpd[1890]: Connection established to 193.232.49.4, 1701. Local: 37693, Remote: 23287 (ref=0/0).
Sep 24 16:51:49 ServerPI xl2tpd[1890]: Calling on tunnel 37693
Sep 24 16:51:49 ServerPI xl2tpd[1890]: Call established with 193.232.49.4, Local: 21962, Remote: 31537, Serial: 1 (ref=0/0)
Sep 24 16:51:49 ServerPI xl2tpd[1890]: start_pppd: I'm running:
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "/usr/sbin/pppd"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "plugin"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "pppol2tp.so"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "pppol2tp"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "7"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "passive"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "nodetach"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: ":"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "refuse-pap"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "auth"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "require-chap"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "name"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "user6260"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "debug"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "file"
Sep 24 16:51:49 ServerPI xl2tpd[1890]: "/etc/ppp/options.l2tpd.client"
Sep 24 16:51:49 ServerPI pppd[1911]: Plugin pppol2tp.so loaded.
Sep 24 16:51:49 ServerPI pppd[1911]: In file /etc/ppp/options.l2tpd.client: unrecognized option 'crtscts'
Sep 24 16:51:49 ServerPI xl2tpd[1890]: child_handler : pppd exited for call 31537 with code 2
Sep 24 16:51:49 ServerPI xl2tpd[1890]: call_close: Call 21962 to 193.232.49.4 disconnected
Sep 24 16:51:49 ServerPI xl2tpd[1890]: Terminating pppd: sending TERM signal to pid 1911
Sep 24 16:51:49 ServerPI xl2tpd[1890]: get_call: can't find call 21962 in tunnel 37693#012 (ref=0/0)
Sep 24 16:51:52 ServerPI xl2tpd[1890]: get_call: can't find call 21962 in tunnel 37693#012 (ref=0/0)
Sep 24 16:52:17 ServerPI xrdp[491]: (491)(1995489888)[INFO ] A connection received from: ::ffff:189.76.192.102 port 54110
Sep 24 16:52:18 ServerPI xrdp[491]: (491)(1995489888)[DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.104 port 3389)
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[INFO ] Using default X.509 key file: /etc/xrdp/key.pem
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[DEBUG] Security layer: requested 3, selected 0
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.104 port 3389)
Sep 24 16:52:18 ServerPI xrdp[1913]: (1913)(1995489888)[ERROR] Listening socket is in wrong state, terminating listener
Sep 24 16:52:20 ServerPI xrdp[491]: (491)(1995489888)[INFO ] A connection received from: ::ffff:78.30.214.95 port 55086
Sep 24 16:52:20 ServerPI xrdp[491]: (491)(1995489888)[DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.104 port 3389)
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[INFO ] Using default X.509 key file: /etc/xrdp/key.pem
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[DEBUG] Security layer: requested 3, selected 0
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.104 port 3389)
Sep 24 16:52:20 ServerPI xrdp[1914]: (1914)(1995489888)[ERROR] Listening socket is in wrong state, terminating listener
Время создания страницы: 0.117 секунд
