Низкая скорость при тарифе "HD Видео"
7 года 2 мес. назад - 7 года 2 мес. назад #13 от ILGAS
опять были проблемы, вчера опять у меня не было доступа к моему серверу, думал что то с сервером, сегодня подключился но там показывало что vpn работает, но связи не было. (сейчас все переделал на msk.vpnki.ru)
вот данные
C:\ip>iperf3.exe -c 172.16.9.153 -w 208KB -t 60
Connecting to host 172.16.9.153, port 5201
[  4] local 172.16.9.156 port 50136 connected to 172.16.9.153 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec   256 KBytes  2.10 Mbits/sec
[  4]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec
[  4]   2.00-3.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   3.00-4.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   4.00-5.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   5.00-6.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   6.00-7.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   7.00-8.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   8.00-9.00   sec   128 KBytes  1.05 Mbits/sec
[  4]   9.00-10.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  10.00-11.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  11.00-12.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  12.00-13.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  13.00-14.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  14.00-15.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  15.00-16.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  16.00-17.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  17.00-18.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  18.00-19.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  19.00-20.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  20.00-21.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  21.00-22.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  22.00-23.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  23.00-24.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  24.00-25.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  25.00-26.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  26.00-27.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  27.00-28.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  28.00-29.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  29.00-30.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  30.00-31.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  31.00-32.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  32.00-33.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  33.00-34.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  34.00-35.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  35.00-36.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  36.00-37.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  37.00-38.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  38.00-39.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  39.00-40.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  40.00-41.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  41.00-42.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  42.00-43.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  43.00-44.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  44.00-45.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  45.00-46.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  46.00-47.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  47.00-48.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  48.00-49.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  49.00-50.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  50.00-51.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  51.00-52.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  52.00-53.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  53.00-54.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  54.00-55.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  55.00-56.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  56.00-57.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  57.00-58.00  sec   128 KBytes  1.05 Mbits/sec
[  4]  58.00-59.00  sec   256 KBytes  2.10 Mbits/sec
[  4]  59.00-60.00  sec   384 KBytes  3.14 Mbits/sec
[  4]   0.00-60.00  sec  7.50 MBytes  1.05 Mbits/sec                  sender
[  4]   0.00-60.00  sec  7.34 MBytes  1.03 Mbits/sec                  receiver
iperf Done.
PS город находится в Московской области г. Талдом.
7 года 2 мес. назад #14 от admin
Происходящее мне не понятно.
Я сейчас запустил для вас iperf на сервере. Попробуйте такую команду сначала с одного туннеля, а затем с другого:
iperf -c 172.16.0.1 -M 1440 -t 60
7 года 2 мес. назад #15 от ILGAS
C:\ip>iperf3 -c 172.16.0.1 -M 1440 -t 60
iperf3: error - unable to connect to server: Connection refused
7 года 2 мес. назад #16 от ILGAS
скачал другую версию.
C:\ip2>iperf -c 172.16.0.1 -M 1440 -t 60
WARNING: attempt to set TCP maximum segment size to 1440, but got 1281
Client connecting to 172.16.0.1, TCP port 5001
TCP window size:  208 KByte (default)
[  3] local 172.16.9.156 port 51775 connected with 172.16.0.1 port 5001
[  3]  0.0-60.0 sec  19.4 MBytes  2.71 Mbits/sec
[  3] local 172.16.9.153 port 54405 connected with 172.16.0.1 port 5001
[  3]  0.0-60.0 sec  53.5 MBytes  7.47 Mbits/sec
7 года 2 мес. назад #17 от admin
Понятно. Теперь нужно понять почему в первом случае скорость низка.
На стороне сервера для этих туннелей одинаковые настройки, но ... скажите,
первый туннель - это какой протокол?
7 года 2 мес. назад #18 от ILGAS
первый openvpn,
другие не могу запустить, винда по какой то причине не хочет работать c pptp
