Нет связи между разными сетями (MikroTik)
3 года 4 мес. назад #7 от craftman
craftman ответил в теме Нет связи между разными сетями
запустил пинг адреса 172.16.57.159 с устройства с адресом 172.16.57.160
Вроде бы всю маршрутизацию по dhcp подхватил, пинга нет, таймаут...
3 года 4 мес. назад #8 от admin
Вот результат
00:19:17.684870 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 267, length 30
00:19:18.693600 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 268, length 30
00:19:19.697562 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 269, length 30
00:19:20.746733 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 270, length 30
00:19:21.709508 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 271, length 30
00:19:22.719860 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 272, length 30
00:19:24.230372 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 273, length 30
00:19:25.265808 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 274, length 30
00:19:26.266358 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 275, length 30
00:19:27.252648 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 276, length 30
00:19:28.260198 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 277, length 30
00:19:29.280229 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 278, length 30
00:19:30.274781 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 279, length 30
00:19:31.276768 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 280, length 30
00:19:32.281607 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 281, length 30
00:19:33.290942 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 282, length 30
00:19:34.293099 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 283, length 30
00:19:35.335341 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 284, length 30
00:19:36.306833 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 285, length 30
00:19:37.318025 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 286, length 30
00:19:38.318799 IP 172.16.0.0 > 172.16.57.159: ICMP echo request, id 198, seq 287, length 30
В качестве исходящего адреса указан адрес сети 172.16.0.0 что не корректно. Поэтому только request, но нет ответов. В качестве источника должен быть 172.16.57.160. Кажется где-то ошибка в настройке интерфейсов на Микротике...
3 года 4 мес. назад - 3 года 4 мес. назад #9 от craftman
ага, ясно. Такую маршрутиизацию микротик получает по dhcp при подъеме ppptp интерфейса, осталось выяснить как его убедить не получать подобные маршруты, да еще и с длинной маршрута 0, то есть добавить статический маршрут на те же сети с более коротким маршрутом не получится =). Причем dhcp клиент не настроен на интерфейсе pptp(в смысле отдельной настройки нет, в настройках клиента нет интерфейса pptp), как это победить теперь не понятно.
3 года 4 мес. назад #10 от craftman
Разобрался с источником "появления" не верных динамических маршрутов с метрикой 0 в таблице маршрутизации микротика. Они появлялись от того, что все сети мною были прописаны в IP->Addresses. Вот так, а казалось бы, первые микротики настраивал еще лет 10 назад, и с тех пор для меня микротик "родной" =)
3 года 4 мес. назад #11 от admin
Значит теперь проблема решилась? Тогда поздравляю с победой :)
3 года 4 мес. назад - 3 года 4 мес. назад #12 от craftman
Да, все работает, доступ к сети маршрутизатора полный. Спасибо, будем пользовать Ваш сервис.
Спасибо сказали: admin
