не получается настроить доступ с телефона в домашнюю сеть.
5 мес. 2 нед. назад #19 от vvvet
содержимое .ovpn файла:
client
remote msk.vpnki.ru 37999
proto udp
cipher none
ns-cert-type server
key-direction 1
dev tun
auth-user-pass
explicit-exit-notify 2
reneg-sec 0
route 192.168.1.0 255.255.255.0 net_gateway (можно vpn_gateway)
а это выдает лог:
[мая 15, 2026, 09:41:41]
OpenVPN Start
[мая 15, 2026, 09:41:41] EVENT: CORE_THREAD_ACTIVE
[мая 15, 2026, 09:41:41] OpenVPN core 3.11.1(3.git::fbda4753:RelWithDebInfo) android arm64 64-bit PT_PROXY
[мая 15, 2026, 09:41:41] Frame=512/2112/512 mssfix-ctrl=1250
[мая 15, 2026, 09:41:41] NOTE: This configuration contains options that were not used:
[мая 15, 2026, 09:41:41] Unsupported option (ignored)
[мая 15, 2026, 09:41:41] 0 [explicit-exit-notify] [2]
[мая 15, 2026, 09:41:41] EVENT: RESOLVE
[мая 15, 2026, 09:41:41] Contacting 84.201.157.25:37999 via UDP
[мая 15, 2026, 09:41:41] EVENT: WAIT
[мая 15, 2026, 09:41:41] Connecting to [msk.vpnki.ru]:37999 (84.201.157.25) via UDP
[мая 15, 2026, 09:41:41] EVENT: CONNECTING
[мая 15, 2026, 09:41:41] Tunnel Options:V4,dev-type tun,link-mtu 1525,tun-mtu 1500,proto UDPv4,keydir 1,cipher [null-cipher],auth SHA1,keysize 0,tls-auth,key-method 2,tls-client
[мая 15, 2026, 09:41:41] Creds: Username/Password
[мая 15, 2026, 09:41:41] Sending Peer Info:
IV_VER=3.11.1
IV_PLAT=android
IV_NCP=2
IV_TCPNL=1
IV_PROTO=8094
IV_MTU=1600
IV_CIPHERS=AES-128-CBC:AES-192-CBC:AES-256-CBC:AES-128-GCM:AES-192-GCM:AES-256-GCM:CHACHA20-POLY1305
IV_GUI_VER=net.openvpn.connect.android_3.7.1-10568
IV_SSO=webauth,crtext
[мая 15, 2026, 09:41:42] SSL Handshake: peer certificate: CN=VPNKI, 2048 bit RSA, cipher: ECDHE-RSA-AES256-GCM-SHA384    TLSv1.2 Kx=ECDH     Au=RSA   Enc=AESGCM(256)            Mac=AEAD
[мая 15, 2026, 09:41:42] Session is ACTIVE
[мая 15, 2026, 09:41:42] Sending PUSH_REQUEST to server...
[мая 15, 2026, 09:41:42] EVENT: GET_CONFIG
[мая 15, 2026, 09:41:42] OPTIONS:
0 [route] [192.168.1.0] [255.255.255.0] [net_gateway]
1 [route-gateway] [172.16.0.1]
2 [topology] [subnet]
3 [ping] [10]
4 [ping-restart] [120]
5 [ifconfig] [172.16.72.26] [255.255.0.0]
6 [peer-id] [0]
7 [cipher] [AES-256-GCM]
8 [block-ipv6]
9 [block-ipv4]
[мая 15, 2026, 09:41:42] PROTOCOL OPTIONS:
  key-derivation: OpenVPN PRF
  control channel: tls-auth enabled
  data channel: cipher AES-256-GCM, peer-id 0
[мая 15, 2026, 09:41:42] EVENT: ASSIGN_IP
[мая 15, 2026, 09:41:42] Connected via tun
[мая 15, 2026, 09:41:42] EVENT: CONNECTED info='user21801@msk.vpnki.ru:37999 (84.201.157.25) via /UDP on tun/172.16.72.26/ gw=[172.16.0.1/] mtu=(default)' trans=TO_CONNECTED
[мая 15, 2026, 09:46:51] EVENT: CANCELLED
[мая 15, 2026, 09:46:51] EVENT: DISCONNECTED
[мая 15, 2026, 09:46:51] Tunnel bytes per CPU second: 0
OpenVPN Stop
[мая 15, 2026, 09:46:51] EVENT: CORE_THREAD_DONE
С телефона 172.16.0.1 и 172.16.0.2 пингуются нормально. А вот уже 172.16.0.3 - выдает, что узел недоступен
5 мес. 2 нед. назад #20 от admin
С опенвпн все выглядит корректно.
Меня смущает Wireguard. Ожидаю, что вы все же выполните пинг 172.16.0.1 и 172.16.0.2 с роутера, а не с ноутбука в домашней сети.
5 мес. 2 нед. назад #21 от vvvet
выше выложил сообщение со скринами с роутера
5 мес. 2 нед. назад #22 от admin
Ага, теперь увидел. Выглядит так, что пинг идет, но ... меня не оставляет ощущение, что соединение Wireguard не работает корректно. Если вы можете сейчас выполнить пинг еще раз, то давайте я включу дебаг на сервере и убедимся, что действительно до сервера все доходит.
Включил дебаг
5 мес. 2 нед. назад - 5 мес. 2 нед. назад #23 от admin
wg0_vvvet Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:172.16.0.2 P-t-P:172.16.0.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MTU:1420 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:48 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Судя по данным на странице Инструменты интерфейс, который ведет к вашему роутеру ни разу не принял ни одного пакета (RX), но пытался передавать TX, да и то- с ошибкой.
5 мес. 2 нед. назад #24 от vvvet
странно от меня то пинг идет без потери пакетов...
что то где то работает неправильно...
